  • 21 Vote(s) - 2.86 Average
Seat Belt
The plastic surround on the passenger seat-belt buckle has broken. Glue has temporarily solved the problem, but wish to replace with a salvaged part.
Easy un-bolt and replace?
No!
Pretensioner...
Guessing the silver part is a small explosive charge (see photo).
What is the correct procedure for removal?
Do I need to inform the Police to cordon off the van and call the Bomb Squad?
Do I cut the red wire or the blue....
Seriously... is it just a case of disconnecting the plug and un-bolting the assembly?
[Image: 2pt1og2.jpg]
Follow this link for correct procedure for battery disconnection(BSI Reset)
http://www.bba-reman.com/content.aspx?co...ot_process
After disconnecting battery allow a minimun of 10 to 20 minutes I wait 30. Then it should be safe to unplug & remove pretensioner .
Store pretensioner in a safe / secure place.
Refit pretensioner & connect.Then carry on with BSI reset procedure.
2003 Citroën Berlingo 2.0HDi Multispace Desire
[-] The following 1 user says Thank You to BlueBlingo for this post:
  • j90xxx
What exactly does this explosive charge do?? I thought the belts had inertial locks and that was it. Thanks for any info.
Tom
(04-09-2011, 04:17 PM)3rensho Wrote:  What exactly does this explosive charge do?? I thought the belts had inertial locks and that was it. Thanks for any info.
Tom
Hello Tom, explosive charge is in a cylinder beneath the seat. Coupled to the seat belt and interconnected with the air-bag system. In the event that it is triggered, it pulls the seat belt extra taught for want of a better description, within a split second and prevents any movement of the upper body.
  • 3rensho
Tom
it pulls the seatbelt in tighter in the event of an accident, hence the name, pre-tensioner.
[-] The following 1 user says Thank You to steve valentine for this post:
  • 3rensho
Hi, guys.
There's no necessity to fulfill reset for BSI. Just do like BlueBlingo said and everything will be ok.
You can buy belt buckle separately. Sparepart number 8973 GC.
Price for dealers - 45,50 €
[-] The following 1 user says Thank You to pk7478 for this post:
  • j90xxx
Thanks for the explanation. Never realized I was sitting on a bomb Big GrinBig Grin
Tom
So just disconnect battery and wait, then separate plug, un-bolt and replace. Sounds straightforward.
Can I give the removed item to the kids next door.......???:whistle:
(05-09-2011, 08:33 AM)j90xxx Wrote:  So just disconnect battery and wait, then separate plug, un-bolt and replace. Sounds straightforward.
Make sure you discharge any static electricity from yourself before you unplug and fiddle with the pretensioner. Also, keep your fingers away from the cable from the seat belt buckle where it meets the bracket of the pretensioner. The cable doesn´t move far but it would make a mess of your fingers.
These things do go off with a "BANG" - having one of these go off in your hands would be a definite and immediate cure for constipation :lol:
Yesterday 10:15 PM
Not able to register
Last Post: Pricklybuzzz
Yesterday 09:02 PM
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 03:30 PM
M59 rear wheel splay...
Yesterday 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
Yesterday 03:09 PM
Last Post: pondweed
Yesterday 01:21 PM
Yesterday 12:41 PM
Yesterday 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
Last Post: Matt Haigh
Yesterday 12:43 AM
User Registration Problems
Last Post: Mike
20-01-2025 10:39 PM
