[Engine] Fuel Line layout information
I need a little bit of help with a 2000 1.4l petrol Berlingo.
The berlingo was stripped and engine removed and I picked it up for $200 and I am puting it back together for a second car for work etc.
The fuel lines where cut and pulled out back to the tank. I have some of the lines and I have parts from my own berlingo project but I am a little confused as the fuel rail only has 1 inlet and no return but obviously there is a return line at the fuel tank.
Does someone have drawings of what and where the pipes are going? Is the black plastic tank under the driver side front guard a clue?
Also is there meant to be a 3rd black line running from the tank to the engine like a breather/pollution control other cars have?
There is a second part I am unsure of... it's a brown round cylinder the has  wires connected and one end connects to the Air Box, Tapped cover and inlet manifold. it looks like just a push on vacuum hose connects from this to something?
If you need pics or more precise info I can do that.
Ant
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
