Lining your van
Hi everyone , I could do with some advice, I have just joined the forum.
I have just bought a 2014 Berlingo L1 625 airdream van.Previously I had a 2004 Berlingo van.I love the van and would like to look after it a bit better than the last one. My first question is I would like to put a non slip floor in the back, can  anyone recommend a good floor and company that provides delivery, I would prefer it as one piece if that's possible. Can you get away with not screwing them to the van I don't really want to put holes in my precious van , is there any other methods of holding the floor down.
 thanks gunta
I bought a piece of 6mm thick plywood cut to size, and stuck rubber sound deadening material on the underside. You will need to cut 6 x 3" holes in the edges to allow access to the swivelling load lashing eyes in the van floor. I have never screwed a floor down in the back of my van ever. The rubberised sound deadening material tends to hold it in place anyway, but you will have to be careful, and watch out for the forktruck driver who will try and drag a heavy pallet out, and drag your floor out with it! You can always attach the front edge of the floor to the bulkhead if need be, to stop it moving.
[-] The following 1 user says Thank You to CourierJim for this post:
  • whitebus
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
