Introduction
Just to say hello,my son has just bought a 2010 xtr for work and European trips.Not a stranger to Citroen or diesel as he previously had a xsara hdi estate(which had a misshap) And before that a 405  1.9 405 peugeot.Both totally reliable cars.Also run a 1989 Sierra  2.3D estate owned for 24 trouble free years.Realise these PSA engines are quite sophisticated and do need regular servicing. So will be changing oil and filter at 6 K mile intervals.So first question the gauz  e filter in turbo oil feed is this a service item?.Car will be doing about 18k miles a year.Thanks.
Hi & welcome.There is a thread on turbo pipe filters but the general consencus is to remove it & keep the oil clean.6,000m change is ideal but don't skimp on oil quality.
Hello Exiger welcome to the forum Smile the gauz is not a service item remove mine two year a go there is a man on here called Lighty has done many turbo's on PSA fit's a oil feed pipe with out the gauz as he said never had one back with a failed turbo you can remove it your self or bye one form Citroen with out it on if you have a 110 ps you will have a fap / dpf on it that make it a bit harder to change the oil feed pipe you have to move the fap / dpf and feed pipe's work to get to the oil feed pipe it will take a little bit longer .
Yesterday 10:10 PM
» Replies: 21
Berlingo undertray
Yesterday 09:59 PM
» Replies: 19
Air filter box removal
Yesterday 06:18 PM
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
