Interior Light Problem
Hi Guys
I have a 2000 Berlingo Multispace Forte and ever since i`ve had it one of the load area interior lights does`nt work,
I have tried a new bulb and a replacement light from the scrappies and still no joy,
The passenger side one works perfectly my question is would there be a separate fuse for the driver side one?
Cheers
Adrian
Ive taken a look at the Haynes manual and in there it shows only one light even though there is 2 fitted in the vehicle so i would assume its another Haynes boo boo,which is fairly typical. Anyway there appears to be only one fuse ,that being F25 @ 5 amp.There's one feed and 2 earths on the interior lights, one earth is via the door switch and the other makes the circuit when you turn the light on manually,so its unlikely that both earths have failed,i would start by testing the feed wire which would appear to be grey in the drawing down to a known good earth,if you are sure that wire is dead then have a look to see if the grey feed wire is looped from the other side,if you cant find where the feed wire is coming from then it could be a break in the wire further back in the loom.
I do hope that may be of help.If its not then ill have a look at my MK 1 and see if i can find an answer for you.All the best.
Thanks Graham
I have a grey wire that comes from one pin in the plug then loops back into another pin on the same plug?
Last Post: TGD
Today 09:50 PM
Today 12:29 PM
Last Post: CB-K9murph
Yesterday 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
