[Engine] starter motor
Good evening I have a 1.6hdi 2008 berlingo van and wondered if someone could explain how to get the starter motor off as I can only see one bolt so far. the problem started today my key stuck in the start position and the starter motor was running for about 15min whilst I was driving and did not notice as radio was on .and now wont start on key but will bump only. so thinking of changing starter motor to see if it will solve the problem.many thanks
there are 3 bolts holding the starter.one near the clutch cable and the others are more or less 6 inch apart.remove the cables and out it comes itookmine upwards but it may go down under the car easier
[-] The following 1 user says Thank You to lorraine for this post:
  • nobelz66
nobelz66
See attached picture
Attached Files Thumbnail(s)
[-] The following 2 users say Thank You to pk7478 for this post:
  • nobelz66, ron
Many thanks for your help .
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
