Thanks Given: 1
I want to fit a new speedo to my berlingo because the previous owner has taken out the led for the airbag and another light. If I swap it will my mileage be correct or is it stored in the speedo. Also does it need coding or is it plug and play? Thanks in advance.
Thanks Given: 188
23
Hi bowser welcome to the forum, if you do a search on the forum for speedo it will bring up a load of threads and some on the subject you are looking for. I seem to remember that if you change the dash the bsi retains your mileage but will not display it. It can be set up correctly but you will need to connect it up to lexia/diagbox diagnostic equipment.
Are we there yet?????
• Bowser100
