Threads: 3
hi
does anybody know can you change the brushes
in the heater blower motor (1999 1.9d)
thanks
Threads: 23
Thanks Given: 50
29
Hello hampy i think you'll find that the motor is sealed so you will be unable to service the bushes if you could you got to think the bearing's mite be past there best new motor would be better
Threads: 67
Thanks Given: 238
50
Give it a go there is nothing to lose ......
Serieal Berlingo owner
Threads: 2
Thanks Given: 2
Before you strip out the motor, give the contacts on the base of the unit a good clean (both the spades and the connectors on the wiring). That can make a big difference.
HTH
