2.0 HDI w/Torque OBD
Threads: 6
Thanks Received: 9 in 7 posts
Thanks Given: 1
[Image: IMG_2977.jpg]
Bought a cheap Bluetooth OBD reader from amazon, Dl'd Torque obd, Works perfectly! Allows you to monitor Engine load, Intake temp, Fuel rail pressure, Engine coolant temp, MAF readings, Estiates MPG. Works with my Siemens ECU. Reads Fault codes, Cost me <£15!
Pretty cool and cheap way to keep an eye on things!
Threads: 13
Thanks Received: 139 in 113 posts
Thanks Given: 162
18
(01-12-2015, 10:09 AM)DanClark Wrote: Bought a cheap Bluetooth OBD reader from amazon, Dl'd Torque obd, Works perfectly! Allows you to monitor Engine load, Intake temp, Fuel rail pressure, Engine coolant temp, MAF readings, Estiates MPG. Works with my Siemens ECU. Reads Fault codes, Cost me <£15!
Yes, it is really cheap and it works
http://www.aliexpress.com/item/Universal....19.3PaIji
Best regards,
brajomobil
Thanks Received: 23 in 20 posts
Thanks Given: 18
(01-12-2015, 10:09 AM)DanClark Wrote: [Image: IMG_2977.jpg]
what one have you got? I ave one which doesn't work
(02-12-2015, 08:24 AM)brajomobil Wrote: (01-12-2015, 10:09 AM)DanClark Wrote: Bought a cheap Bluetooth OBD reader from amazon, Dl'd Torque obd, Works perfectly! Allows you to monitor Engine load, Intake temp, Fuel rail pressure, Engine coolant temp, MAF readings, Estiates MPG. Works with my Siemens ECU. Reads Fault codes, Cost me <£15!
Best regards,
brajomobil
This is the one i have that doesn't work, my van is a 1.9d
Threads: 13
Thanks Given: 162
18
04-12-2015, 05:23 AM
(This post was last modified: 04-12-2015, 06:00 AM by brajomobil.)
This is like number 10 that I ordered. They all work ok. Try yours in another car. Petrol staring from 2001 and diesel starting from 2005 year.
Search the forum and you can find numerous posts about 1.9d not comapatible with cheap obd2 code reader.
Best regards,
Brajomobil
Sent from my LG-F320L using Tapatalk
Threads: 6
Thanks Given: 1
This is the one i use. It works with my 2005 2.0 HDI with siemens ecu. I had to start the engine to pair it with my phone. works perfectly.
http://www.amazon.co.uk/Stoga-Bluetooth-...etooth+obd
Berlingo undertray
Today 07:56 AM
» Replies: 16
Today 07:07 AM
Yesterday 08:32 AM
Yesterday 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
