Newbie - General stuff 1.6HDi 90 2010
Greetings all. Newbie to the Berlingo club due to recent purchase of 2010 1.6 HDi 90 VTR for our disabled son. Not too bad with mechanics having restored a few classic cars and bikes, and would be very grateful if anyone could give some guidance on the following...
Does not appear to be Haynes manual for this model/engine. Anything similar about? Workshop manual?
Anything in particular I should do to it or watch out for? I intend to change out oil, filter and air filter soonest.
Type of oil used please? 5W/30 rings a bell....
Is the steering wheel column adjustable? If so, how! - profuse apologies for being a berk, but I cannot see anything obvious...
That will do...for now...
Much appreciated
Mark
Citroen recommended oil is Total ineo ECS 5w/30 or vist websites of other oil makers & input reg number on oil finder page to find their correct grade. It's vital for these engines correct grade of oil is used & also correct drain procedure. Click here
Adjust column, reach underneath to left side bottom of column, hook fingers under lever, pull forward & you can adjust column.
  • Shawks
Hi Oggy, welcome to the site.
You need to be very particular with the oil type and change times to help the turbo last on these cars. Please to a search for this on here.
Yes you can adjust the steering, from memory the adjustment is done via a lever by your left knee under the column.
Sadly there is no Haynes book for these newer Berlingos.
Thank you gents - much obliged. Incidentally, in order to drain the oil, is jacking up one side adequate to get at the drain plug - or do I need a trolley jack on the subframe under the front of the vehicle? Also, which side?
I jack up the one side with a trolly jack much easier and safer than other jacks. If you plan on doing your own maintenance then invest in one. You can get a reasonable one from Halfords or Machine Mart for not much money.
Use this site for your oil its very cheap and good service https://www.nielsencdg.co.uk/acatalog/To...-Ineo.html
  • ron
And with the trolley jack, get one of those insert things so you don't damage the car.
The air filter is a right pain to get at, almost as bad as the pollen filters (if you have A/C), but essential as it may have been 'forgotton' by a lazy previous mechanic. You don't wants chunks of old filter heading towards the turbo!
Hello Oggy welcome to the forum do has these gent's said the berlingo will serve you well for many a year  Smile
Chaps
Yes indeed, I have read up on the air filter and it looks to be somewhat fiddly to say the least. I do set great store by proper maintenace - especially oil changes on diesel turbos - but Citroen do not make it easy!
I am afraid I also never trust any dealer or any chain-store garage with regard to previous service history. Much rather DIY if I can - so I can be 100% certain it is done.
Is the oil change and oil type the same for the 75HP engines?
2010 Berlingo Multispace 1.6HDi - Chipped
(04-12-2015, 04:22 PM)old son Wrote:  Is the oil change and oil type the same for the 75HP engines?
If you mean 1.6hdi 75hp then yes its 5w30 fully synthetic low saps, see the oil link in my previous post.
footwell fan
Last Post: de62
Yesterday 10:13 PM
knocking from rear
Last Post: Brooky325
Yesterday 10:03 PM
rear washer fires front?
Yesterday 10:00 PM
Last Post: IKUN
Yesterday 06:34 PM
Remote key fob window function?
Yesterday 05:58 PM
Yesterday 05:48 PM
Halp, me van had died :(
Last Post: ae3
Yesterday 05:43 PM
Drop in fuel economy
Yesterday 09:38 AM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
Frequent DPF REGEN's
11-01-2025 08:59 AM
