03-12-2015, 10:14 AM
I think I inadvertently posted the following into the wrong forum a couple of days ago so am giving it another try:
Both the 'airbag deactivated' and the 'airbag fault' warning lights lights remained on when I went out this morning and in my search for possible causes found a thread in which many contributors mentioned that wiggling the connector at the front of the driver's seat cleared the problem. Nobody mentioned shutting down the system just try the wiggle test so is that only necessary if you intend to actually disconnect it? I also thought I'd try switching the deactivate switch on the door pillar on and off a few times to see if there was a bad contact there but when I tried to switch it to off it just sprung back to the on position. Is this an indication of a definite fault or did I just not force the key round far enough? After switching the ignition on and the system check has finished, I get a warning beep but not the warning notice on the display which is mentioned in the handbook. The vehicle is a late 2008 Autosleeper Mezan camper based on the Partner LX800 chassis cab and I do have a passenger airbag which is always activated at the moment.
] and let them dry out before re-assembly. Please do not use WD40 as some on here recommend, as WD40 is not good for electrical contacts [as it doesn't dry out/evaporate for a long time and even when it does it leaves a residue on the contacts] It is also worth using some tie-wrap straps to secure the connectors to the seat to stop them hanging down. Make sure if you do you leave enough slack for the seat to run along it's full travel.
