Van rear door lock question
Hello all...
  I had the battery disconnected for a couple of days... other issues..
      The central locking works open and close but when the rear doors are open the central locking will still lock. I am using the key in the drivers door lock as I have never had a key fob so I assume the van hasn't got remote central locking..
  This has only been like this since reconnecting the battery and waiting for the BSI to set.. I know that holding the dash button in will set the doors to lock when over 5mph, is there a way of setting the central locking so it will not activate if one of the doors is open like it did before.
  The other possibility is a faulty rear door micro switch but when I took the lock out I found only two wires going to the solenoid and all the other wires tied back,, the van doesn't have rear wash wipe. Is there a micro switch somewhere ? How does the loading light know the door is open / closed ?
  Any ideas ?
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
OK, forget about the disconnected battery, I'm thinking the problem is with a micro switch, the BSI thinks the back doors are closed ? Where is the microswitch for the back doors in a van ? is it in the door ( bottom catch ) or in the black metal striker think mounted on the rear slam panel / floor ?
Does anyone have the part number ?
Any one know where the micro switch is for the rear doors on a van ??
my switch is just above the top hinge on the offside door,held in with 1 screw,easily visible in the door recess when it's open,mines 08 1.6hdi van with barn doors...Ian
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
Hiya,thanks for your reply. I found it and gave it a spray with some contact spray and hey presto, no problem since..
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
