Terrible quality
Smile
Had to change the front pads,only managed 132450 miles with them,rears still like new on same mileage,mechanic can't get over it :-).
Changed heater plugs no drama's, all filters fresh oil and drained the gearbox and put fresh in,lovely and sweet change now,ready for the busy run upto Xmas peep peep. :-)
[Image: smokingdog-1.gif]
Berlingo First,75bhp 1.6hdi,58 plate....225k and counting.
(06-12-2015, 01:26 PM)ians_lingo Wrote:  Had to change the front pads,only managed 132450 miles with them,rears still like new on same mileage,mechanic can't get over it :-).
My pads are less than half worn @ 48,000m.I bet you get really good mpg as well as me. Big Grin
  • ians_lingo
Sounds to me like a faulty brake distribution valve ? This is located under the car near the rear axel and has a large spring attached to it. They do get stuck because they get gummed up with road crap. Might be worth a look at...
 Riding the brake pedal will also cause front brake wear as will binding callipers.. Unless the vehicle  is an Automatic, then the front brakes will take a bit more of a beating than a manual due to the lack of engine breaking..
 Were the break pads Original or pattern ? I find pattern brake parts don't last and quite often the pads are considerably more dusty.
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
(06-12-2015, 05:58 PM)ajcommercial Wrote:  Sounds to me like a faulty brake distribution valve ? This is located under the car near the rear axel and has a large spring attached to it. They do get stuck because they get gummed up with road crap. Might be worth a look at...
134+k, I was been sarcastic :-) I wasn't sure if you'd miss-read the post,
 I don't use the brakes at all unless really necessary,she gets a check-up/service every 8k,same mechanic/garage and he knows his lingo's, it's brushed down and greased underneath if/when he reckons it needs it,this has to last as long possible. Ian
I thought I was good getting 60k plus out of my pads...
Anyway - I agree with the post title - terrible French piece of rubbish. Mines up past 70k now and I have to give it an oil change and wipe with an oily rag every year... It even demands a fresh tank of diesel most weeks. Ridiculous!
Spare key programming ?
Today 02:37 PM
Rear electric window regulators
Last Post: phydaux
Yesterday 10:27 PM
Adding aircon oil after component replacement
Last Post: Ian_99
Yesterday 09:37 PM
Problem Passenger Electic Window
Last Post: pavb2
Yesterday 06:49 PM
Solenoide, Wastegate
Last Post: BerlingoCitroen2011
Yesterday 06:44 PM
New user
Last Post: nonce
Yesterday 01:42 PM
Brake problems again!
08-07-2025 03:38 PM
ServiceBox
Last Post: nonce
07-07-2025 03:28 PM
Limp mode, no other symptoms.
07-07-2025 11:37 AM
Centre Air Vent On Dash
06-07-2025 10:50 AM
