[Filters & Oil] drive shaft gearbox oil
Hi All
I have removed the front strut and pulled the drive shaft out and lost quite a bit of oil.........can some one tell me how to replace the oil where I put the new oil in and how oh and what oil is recomended.
2005 Berlingo Van 1.9d
ThANks in ADVANCE
Hi David welcome to the forum, You need 75w/80 transmission fluid to replace or top up. If its never been replaced I would drain and replace it makes a difference. The drain plug is on the base of the diff housing look for a plug with a 8mm square fitting. The filler plug is on the right hand side of the box as you look at the end plate and is a large hexagonal bolt but if you have a breather on the top of the gearbox you can remove this and pour the oil in through there. You need 1.9 litres in the BE4/5 boxes
  • Art b
(07-12-2015, 09:16 PM)Tomcat3 Wrote:  Hi David welcome to the forum, You need 75w/80 transmission fluid to replace or top up. If its never been replaced I would drain and replace it makes a difference. The drain plug is on the base of the diff housing look for a plug with a 8mm square fitting. The filler plug is on the right hand side of the box as you look at the end plate and is a large hexagonal bolt but if you have a breather on the top of the gearbox you can remove this and pour the oil in through there. You need 1.9 litres in the BE4/5 boxes
Hi Tomcat
Do I need a special filler or pump or can the oil be poured in strait from the bottle.
Thanks for your help.
dave
I've done mine a few weeks back so pretty fresh in mind... As Tomcat says with the addition of ....
1/ The drain plug - in addition to the 8mm square there is also a larger hex around it which you can fit a socket onto if you don't have the square tool.
2/ The filler plug is also the level plug and requires a 19mm ring spanner or socket to remove it. If you buy the litre bottles of oil they come with a pull out nozzle that fits nicely into the hole so yes you can bottle fill.
(08-12-2015, 10:03 AM)geoff Wrote:  I've done mine a few weeks back so pretty fresh in mind... As Tomcat says with the addition of ....
Fantastic...................thanks for the great help and time.
Wink
Users browsing this thread: 2 Guest(s)
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
