citroen berlingo 12v accessory to add safety camera
Hi I world like to 12v accessory in my boot is wireing all ready they in my Citroen berlingo multispace 59 vtr to add safety camera to back window needs to be on when ignition is truned on and off
I added the boot light/torch unit to mine and the wiring was already in place under the side wall covering on right side of auto. Not sure if things are reversed on a RHD vehicle.
Yes it will be - there is a connector block inside the trim on the boot side (left hand side looking into the tailgate). However as standard there won't be any power to it. To power it up you stick a 40amp fuse in one of the spare fuse positions under the bonnet (there are fuse diagrams online)
This is to add a safety camera to the back so when car is turned on camera will work
The power for the boot torch looking in from the boot is on the right hand side the power for the tow itch thick white cable is on the left under the panel and need's a 40 amp fuse put in in the engine bay you have to lift the fuse box and you will see the spare place for the 40 amp fuse to go
PS it's a perm live
(20-12-2015, 10:07 PM)Jed Clampit Wrote:  The power for the boot torch looking in from the boot is on the right hand side the power for the tow itch thick white cable is on the left under the panel and need's a 40 amp fuse put in in the engine bay you have to lift the fuse box and you will see the spare place for the 40 amp fuse to go
PS it's a perm live
Sorry - yes you're absolutely right. I was deliberately after that 40 amp feed as I was using it to power a subwoofer...
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
