Threads: 8
Thanks Received: 1 in 1 posts
Thanks Given: 4
good morning & happy christmas.
just a quick question, can I update or improve the quality of my headlights /lights, in my multispace?
The reason I ask is I also drive a merc, and there is vast difference in headlights between the 2.
I know I cannot fit xenon bulbs, but is there an acceptable alternative?
thanks
kim
Threads: 52
Thanks Given: 87
5
That's one of the first things I did. I put in Osram Night Breaker Plus and noticed quite an improvement. I think that model has been changed/superceded to/by Night Breaker Unlimited now.
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• kimbos1961
Threads: 6
Thanks Received: 9 in 7 posts
Thanks Given: 1
I use night breaker unlimited's, and they are a massive improvement over standard bulbs.
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
Another thing you can do is get a wiring kit with relays to mount in the engine room.
Normally, the relays are mounted under the dash, with relatively thin wires going back there, then forward to the headlights.
Thin wires have a higher resistance, so lead to a higher voltage drop.
The wiring kits have thick wires that mount directly to the battery, go through relays next to the battery, then a short distance to the headlights.
To hook them into the wiring loom, you just take the connector from one of the headlights and plug into a special connector on the new wiring kit. Plug the new light connectors into the lights, and connect to the battery.
Threads: 23
Thanks Received: 5 in 5 posts
Thanks Given: 2
ive got night breakers on mine but bought a set of drl and going to wire them to come on at main beam
Threads: 67
Thanks Given: 238
50
" Is there a reason that Land Rover kit linked above wouldn't work in a Berlingo? As it's an H4 plug and socket it should just plug in "
No reason why not .... cable lengths would be the main thing to check before buying
Serieal Berlingo owner
Threads: 3
Thanks Received: 5 in 3 posts
Thanks Given: 3
that kit is usefull for non canbus lingo's only i think.
Threads: 48
Thanks Given: 4
20
It really depends on where the relay(s) are mounted.
If they're under the dash, then yeah, it will help.
And even if a modern Berlingo has a modern wiring setup with CANbus and a relay in the engine compartment, replacing the wires with thicker ones will probably help.
