  • 16 Vote(s) - 2.63 Average
Gearbox Droning noise
Hi there
First post as I'm a fairly new owner of a 1.4 Berlingo (Y Reg) with 104000 on the clock. It has developed a sort of droning/whining noise when in gear and being driven. It's not there in first gear when pulling away but as the speed increases in 2nd - 5th its more pronounced. As soon as the clutch is pushed in the noise disappears. Also the gear stick is fairly loose and moves around. There is no obvious vibration when driving or any difficulty selecting any gear. Any thoughts?
Cheers
Neil
Hi again
It's been to the garage and the problem is solved........it needs a replacement gearbox. Cheers anyway.
Neil
if its the gearbox why would the noise go away when the clutch is pressed
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
Today 10:07 PM
Engine Fan Running
Today 09:59 PM
Bettery Issues - A Solution.
Today 10:45 AM
Sound proofing windscreen
Yesterday 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
