  • 9 Vote(s) - 2 Average
water ingress (rainwater)1
hi ,i have just joined as i need help !!!!!!!!!!!!!
i have bought a 2004 berlingo van, 1.9d 600lx, i have noticed a leak, the drivers footwell is always damp, plus the sponge section that runs alongside the fusebox is also, i checked the rainwater drain and hey presto was rammed full up with gunk, leaves ,pine needles etc, i managed to remove all of this with a rod and watering can to clear , and it now pours through to the wheel arch as supposed to,great !!! the footwell is still damp a week later ?? i just pulled up the carpet as much as i could its absolutley soaking beneath, !!!!could probably allow a small goldfish to live in quite happily Wink ive just removed a good litre or so with a sponge,there isnt much sign of rust or mold etc so im wondering if this is just the backlog of the water i used to drain the well ?? its not dirty water, and ive now propped up the carpet and removed the plug from floor to aid the drying process, the spongey bit by the fusebox is still wet as well and im not sure if water is still getting in ?? ive trawled the net and was wondering if anyone has a solution ?? idea etc as would be most appreciated, thanks, i also have another problem but that can wait as the van is off the road at the moment, any help would be greatly appreciated
(11-09-2011, 12:25 PM)eliano Wrote:  hi ,i have just joined as i need help !!!!!!!!!!!!!
Just like Eliano, My 2004 Forte Estate leaks in water into the front drivers footwell, even while standing idle. Did anyone help you with this? I can't find an answer, am I using wrong search words? The windscreens drains on mine are all clear. It is so annoying I cut my carpet out to see if I could find out where it is coming in. After a short time I noticed water coming in through the welded wheel arch strengthener behind the accelerator pedal. This is where it is coming in. Puzzle is how is it getting in there. Is there a further drain channel under the windscreen drains, which may be blocked somehow???? I say this because well after I tested it water still kept coming in.
Anyone able to help?
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
