Heater Controls
Shocked
The heater blower is playing up on my 2005 2.0HDI desire. when turn the fan switch  fully to the left you get full blast on the fan and the same when you turn it fully to the right but nothing in between no slow speeds at all. Anyone point me to what could be causing this before i start replacing everything a bit at a time..thankyou..
If it only works on full power its usually the blower resistor pack that has failed. It probably looks something like this. http://www.ebay.co.uk/itm/HEATER-BLOWER-...Sw8cNUM-i0
To get at you go up from underneath the glovebox up under the dash. The wiring unclips then the resistor pack unclips or sometimes there is a screw then you take it out.
Have a search on the forum about it there is quite a bit of info.
Cheers Tomcat3 will have a look about
thinking about it there is a clicking noise coming from the back of the glove box when i operate the switch and i thought it was maybe a relay as thats the sort of noise it was
It could also look like this http://www.johnandchris.screaming.net/be...blower.htm you need to have a look at what type you have before ordering.
that sounds a bit more promising as it has a relay attached and i do get a relay type clicking from it when operated so its out with the screwdrivers tomorrow then to investigate..oh joy..
(07-01-2016, 07:21 PM)Tomcat3 Wrote:  It could also look like this http://www.johnandchris.screaming.net/be...blower.htm you need to have a look at what type you have before ordering.
that was the problem many thanks Tomcat3
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
