[Warning Light] Temperature Gauge Reads high constantly
Had this intermittent problem for a while where the gauge goes high and then drops back down.
I bought a new sensor but never got around to fitting it.
Yesterday from a cold start the gauge immediately went high and stayed their I didn't worry too much about it and have done about 50 miles with it like this.
The cooling fan is on constantly and that is annoying.  Today I attempted to replace the sensor after moving the ducting out of the way and disconnecting the sensor I was unable to remove it.  As a test i plug the new sensor in and left it hanging but not sure if it needs to be inserted to complete the circuit and the symptons were exactly as before.
This is a 2002 Citreon Berlingo Multispace 2.0hdi
(09-01-2016, 02:42 PM)Jason Jordan Wrote:  Had this intermittent problem for a while where the gauge goes high and then drops back down.
A good flush & a new thermostat may be what it needs.Use a good antifreeze.
Certainly sounds like sender is Fubared if gauge is instanly going hot
Quote:As a test i plug the new sensor in and left it hanging but not sure if it needs to be inserted to complete the circuit and the symptons were exactly as before.
Can't remember the type of sender that engine uses but there are 2 basic types, either a variable resistor between 2 pins, or a variable resistor to earth, so I expect you might have the latter type. You really need to fix properly for a real test.
I haven't got wiring diagrams with me at the mo, but I think the sender goes direct to the ECU and the ECU then controls the guage and the fan.
Thermostaat?
I DO MISS MY BERLINGO Heart
(09-01-2016, 09:24 PM)philip Wrote:  Thermostaat?
He did say guage went immediately to hot
Faulty sender new one need's to be fitted to work right to get earth of the engine .
Thanks for this i did suspect but really struggling to get my hand underneath to remove the circlip yes its the green one with 2 pins.
Any other ideas, have today managed to change the green sensor not much space but the car still does the same temperature gauge go skies high and cooling fan on full with the flashing stop!
Okay after clearing all the faults with the lexia everything is back to normal.
One thing I did as I dont have the code is program the radio to the vin but its still asking for code is there a way around this.
Jason
Does My Van Have A Tracker ?
Last Post: Mark604
Today 01:40 PM
Today 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
Barn Doors - Lockign Mechanism HELP?
10-06-2025 07:13 AM
09-06-2025 06:25 AM
» Replies: 34
Sump, Any good swear words?
04-06-2025 12:34 PM
6 speed gearbox conversion
Last Post: xtrmark
03-06-2025 05:29 AM
» Replies: 39
