WATER LEAK IN THE QUARTER PANEL
Greetings to all
Looking for some advice in case some else has come across the following (had a search on previous posts but no joy)
Took off the inside back trim to install wiring for tow bar, only to come across a puddle of water inside the back quarter panel on the passenger side (LHS)
Have put a smear of instant gasket on the top grommet feeding the tailgate, also used electrician tape to cover the rear light hole on the body but leak still there
Removed the back driver side trim and it is also leaking but not as bad as the passenger side
Any ideas or experiences gratefully appreciated in advance
Peugeot Partner Tepee 1.6 HDI 2010 (aka Citroen Berlingo B9 VTR)
Is it getting in though the rear lights?
(10-01-2016, 07:13 AM)polar Wrote:  Is it getting in though the rear lights?
Hi Polar
thanks for taking the time to reply
At first this is what I thought, however, covered the aperture with electrician tape. Water leak was still there but not as bad...
The second place that I looked at was the tailgate stop, there is one on either side.... having applied a bead of instant gasket appears to have solved the leak.
Therefore to my mind there has been a lek in two places i.e. the light cluster and the tailgate stop
Given the electrics concealed in that space worrying as hooking up to Lexia it reported a short to earth on both sides
Will update this thread after leaving it a bit and the acid test of pressure washer
Regards
Try a normal hose on a fine spray - get someone to use the hose while you get in the vehicle.
This is what we used to do when i worked at the dealers - i have even found leaks between panels and spot welds this way.
Best of luck.
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
