Threads: 19
Thanks Received: 3 in 3 posts
Thanks Given: 3
hi can anyone with climate control tell me how good it is and can it have different temperatures for driver and passenger, also what options pack is it included with
Paul Ryan
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 1
11-09-2011, 07:07 PM
(This post was last modified: 11-09-2011, 07:09 PM by frafafa.)
Hi,
I have it and it allows you to set different temperatures for driver and passenger: seems to work very well. It should also include a "freezer" for the drawer in front of the passenger.
I say "it should" because in my berlingo it seems not to work and I still have to ask for this to my dealer.
Unfortunately the passenger's drawer is very small and it is difficult to put anything inside of it, so, even if it works like a freezer it would be not easy to put something like a bottle or a little bag insede of it :-(
Here in Italy automatic Climate control is an option that you can choose when you order the car, seems there is no need for any pack. Many options here in Italy are not available, automatic climate control is the only one.
Threads: 4
Thanks Given: 1
unfortunately not, recirculation has to be turned on and off by hand. These little thigs should be easy to be added, I hope that all the cars will have them in the future.
The following 1 user says Thank You to frafafa for this post:1 user says Thank You to frafafa for this post
• PAULRYAN52
Threads: 20
Thanks Received: 57 in 41 posts
Thanks Given: 33
My XTR has climate control,it was part of a pack,but I'm damned if I can remember which one,a quick look at the online brochure and options should tell you.
It works very well,keeps a nice steady temperature which is adjustable for both driver and passenger and I find it much more convenient during the summer.
With manual airco,after a while it tends to get too cold,so you end up turning it off for a while,which makes the car humid and sticky,then turning it on again.
With climate control it will keep a steady temperature which is much more comfortable.
Well worth the money.
Not sure about a 'freezer box' in the glove compartment though,wouldn't think there's enough room.
