B9 Door Rubber Seal
Hi all
anyone aware of third party seal supplier that they have used
the front door seal is torn and hopefully some one knows of a supplier rather than having to go to the stealers
had a look at flee bay and a few used ones there appears these perish quite quickly......., be interested in forum members experience
thank you in advance for the advice
cheers
I'm looking for one as well, so would be interested if anybody has any suggestions
(15-01-2016, 12:24 AM)ntm1275 Wrote:  I'm looking for one as well, so would be interested if anybody has any suggestions
Hi
Had a long look cheapest I could source from the stealers was £57 list being around £65 which is ridiculous TBH .......
Finally I had a search on flee bay for Berlingo B9 that were being sold for parts (search for "breaking berlingo")
The passenger and driver side are both the same (part no 9025G7), therefore try to get the passenger side if possible as it prob has had less wear and tear. Ideally if there is a scrap yard nearby then you can actually inspect the seal before you purchase
To fit you will need to unclip the side panel on the dashboard to allow for properly fitting the rubber back
HTH
Today 01:01 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
