I will be driving down a long hill and the stop light flashes and the engine temp goes from 80'degrees to red line in less than a second. But I open the bonnet and the engine is cold. I disconnect and connect the battery terminal put the ignition on and the temp is back to 80 degrees. All in less than 2 minutes. I've flushed the radiator and engine and it carried on doing it, I took the thermostat out and it still does it. Can anyone help? I have a Citroen Berlin go 1.4 petrol I don't know what year it is I just know what its in the m59 category.
Threads: 20
Thanks Received: 13 in 13 posts
Do you carry out a BSI reset everytime you disconnect/reconnect battery?
Threads: 52
Thanks Given: 87
5
Dodgy temperature sensor?
First of all what is the bsi? And I have also replaced the sensor on top of the water pump.
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
(15-01-2016, 08:00 AM)WaY I R Wrote: First of all what is the bsi? And I have also replaced the sensor on top of the water pump.
Do a google search for BSI. Also if you search this forum for BSI reset, info here.
2001 1.9D Multispace.
Threads: 9
Thanks Given: 316
15
The temperature sensor should be in the head somewhere but to be honest i'm not really up on the petrol engine.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Think later ones had sender on thermostat housing.
I have googled it. I will try tomorrow. And the sensor is on top.
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
there is another sensor UNDER the thermostat housing in the cylinder head behind the metal bracket for the air pipe.
Threads: 23
Thanks Given: 46
5
It may be worth checking you brake fluid level as this problem only happens when going down hill. If its low that may be the cause of the stop light coming on. I have no idea though of why the temp would rise.
