Idle speed eratic
Threads: 2
Thanks Given: 3
I have a 1.8 Petrol, 2000 model. The idle speed has been problematic for a few months. Initially I took it to our usual mechanic and he decided to change the Idle Air Control Motor. The problem persisted, so I took it back and he cleaned something, told me it seemed to be ok, but it wasn't ok for long. I have taken it on myself to have a go, but I must stress that I know very little about mechanics. Having done a fair bit of research, I have learned about the Throttle Body, the Idle Control Valve and the MAP Sensor. It seems to me that my initial action should be to clean these parts. I have armed myself with a can of Throttle Body and Air Intake Cleaner and am ready to go in, trouble is I don't quite know where to go in. I am confident that I have identified the Throttle Body and I think I can see which part is the Idle Air Control Motor, so I will attempt to take those apart and clean them. I have no idea where the MAP Sensor is. Could anyone help me in locating this or offer any other advice please ?
Threads: 20
Thanks Given: 7
14
Be very careful. I'm not up to speed with the berlingo (yet) but when I was in to my Ford Focus the small "reed" switch on the throttle body needed to be cleaned with care. They were very sensitive to what they were cleaned with, if at all you ever cleaned them.
One thing that did cause erratic tick over was the throttle position sensor. Again I must remind you that I'm not up to speed on the lingo yet so hopefully someone will chime in here and give some better advice.
The following 1 user says Thank You to Tree for this post:1 user says Thank You to Tree for this post
• Dave W
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
17-01-2016, 08:52 PM
(This post was last modified: 17-01-2016, 08:53 PM by Col.)
Also check for air leaks around inlet area and vacume pipes including to servo. You can listen for a hissing noise with engine idling. Use a length of rubber or plastic tubing as a stethascope to help pinpoint any noise.
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• Dave W
Threads: 2
Thanks Given: 3
(17-01-2016, 08:48 PM)Tree Wrote: Be very careful. I'm not up to speed with the berlingo (yet) but when I was in to my Ford Focus the small "reed" switch on the throttle body needed to be cleaned with care. They were very sensitive to what they were cleaned with, if at all you ever cleaned them.
Thanks Tree, I'll be very carefull. Won't be able to do it this week, work is getting in the way, very inconvenient, I'll do it next week and let you know how it goes.
Threads: 2
Thanks Given: 3
(17-01-2016, 08:52 PM)Col Wrote: Also check for air leaks around inlet area and vacume pipes including to servo. You can listen for a hissing noise with engine idling. Use a length of rubber or plastic tubing as a stethascope to help pinpoint any noise.
Thanks Col, I'll give that a go as well, I'll let you know how I get on.
Threads: 29
Thanks Given: 67
20
I had the same problem with a Sportage before we got the Berlingo and it was the throttle position sensor. Before I fitted a new one it would rev up to 3000 rpm at the traffic lights then drop to almost stalling. The MAF sensor in the pipe between the air filter and throttle body can affect it as well, try disconnecting it and run the engine see if it levels off.
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• Dave W
Threads: 2
Thanks Given: 3
(18-01-2016, 09:39 AM)ffrenchie Wrote: I had the same problem with a Sportage before we got the Berlingo and it was the throttle position sensor. Before I fitted a new one it would rev up to 3000 rpm at the traffic lights then drop to almost stalling. The MAF sensor in the pipe between the air filter and throttle body can affect it as well, try disconnecting it and run the engine see if it levels off.
Thanks ffrenchie, mine idles anywhere between 900 and 3500 when It's having a funny 5 minutes, but 80% of the time it behaves, it's very intermittent. I'll have a look at those as well, I'll let you know how I get on.
Threads: 2
Thanks Given: 3
Success ! I exposed the throttle valve, removed the idle control valve, removed the MAP Sensor and removed all the electrical connections. The throttle valve and idle control valve were quite clean, so I just gave them a bit of a wipe with some cleaner on a cloth. I squirted all the electrical connections with some contact cleaner. The MAP Sensor was very manky, covered in oil residue, so this is the component that I suspect, I gave it a good clean with the Air Intake Cleaner and then left everything to dry for an hour. I put it all back together and Bingo ! It works, no more problem. Thanks Tree, Col and ffrenchie for your input and support, much appreciated.
Threads: 5
Thanks Given: 3
19
Well done and thanks for the feedback. It's nice to know the outcome of these issues
Threads: 2
Thanks Given: 3
My pleasure, and thanks again.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
