2.0 hdi berlingo wont start
Hello all im new here, i have recently brought a Citroen berlingo 2.0 hdi with Siemons system(rhy) engine was knackered so i have replaced it.  with another rhy engine but was a bosch system so i have swapped everything over. But i am unsure wear two black wires go to nearside engine loom beside the light i have currently put them as earths where the yellow and green ones are . anyway i cranked the van over and it started up straight away turned it off and it wont start anymore cant work it out for love of money. read a few things about a bsi reset but i dont have a original key fob but i do have a aftermarket fob its black with two white buttons it works the alarm. but im really lost with this van.
Welcome to the forum
Have you tried to bleed the fuel again, sometimes they will start and run with the fuel in the pipes etc but wont start again until the fuel system is bled again
As it started and ran I would think you haven't got anything seriously wrong . Don't know about the black wires though, did you try it without them connected.?
i yes i have checked fuel i cracked injectors and fuel is getting up there i tried them withou being connected made no difference
just a update i now have no fuell getting up to rail or injectors
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
