Drive Belt Replacement
Hi
My Alternator Drive Belt snapped today so I naturally went out and bought a new one. Fitted it but then realised there is a bracket in the way that would rub against the belt when turning. Presumably the belt needs to go through the centre of this bracket but i can't figure out how to get it off. Anyone familiar with replacing drive belts? It is a 2005 1.4 Petrol model with Power Steering but no Air Con.
Help! Help! Help! We're supposed to be going on holiday tomorrow so won't have time to take to a mechanic.
Much appreciated.
Does yours look like this?
[Image: b--k06rc.gif]
(21-01-2016, 07:27 PM)Col Wrote:  Does yours look like this?
Hey Col
Yep, that's the one. I figured it had to go through that bracket but can't figure out how to get it off.
Cheers
Unbolt it with the 2 nuts. BTW. Was your belt a clean break or was it a bit shredded? If the latter, or you're unsure, take the cambelt cover off and check no remenants of belt got in there. It can cause the cam belt to jump with disaterous results
  • scotia
(21-01-2016, 08:38 PM)Col Wrote:  Unbolt it with the 2 nuts. BTW. Was your belt a clean break or was it a bit shredded? If the latter, or you're unsure, take the cambelt cover off and check no remenants of belt got in there. It can cause the cam belt to jump with disaterous results
Much appreciated Col. Looks simple enough, I think I must have been staring at it for too long earlier! I still have the whole belt and I can piece it together so it looks like it's a clean break. Might just double check to be on the safe side though
Good luck and enjoy your hol.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
