Threads: 3
Thanks Received: 2 in 1 posts
Thanks Given: 2
24-01-2016, 06:29 PM
(This post was last modified: 26-01-2016, 11:44 AM by caskin43.)
2010 Berlingo Multispace VTR 23000 miles....can the forum please explain any reasons for the large amount of rumbling and noise that appears to be emanating from the rear suspension especially over rough surfaces, is it a design fault or do I have a problem? Thanks
Threads: 4
Thanks Received: 20 in 19 posts
Thanks Given: 5
My 58 plate XTR also has "clunky" rear suspension, I've not tracked down the cause yet (warmer weather job) but I have noticed that if I have weight in the boot the noises largely disappear. Not too concerned about it, apart from the aggravation factor.
Threads: 29
Thanks Given: 67
20
What tyres are fitted and what pressure is in them ?
Threads: 4
Thanks Given: 5
215 55 16 97W XL on mine @ 40lb pressure. I found it handles a lot better with higher pressures
