Threads: 4
Thanks Given: 2
24-01-2016, 07:03 PM
hi guys bit of a pain on my 2002/51 berlingo van.
its had new front discs and pads fitted a few months ago,new track rods, new ball joints,new droplinks also fitted within the last few months too.
it started shaking like mad when braking/pulling up at junctions. at first it was all the time when braking but then when changed the ball joints nd droplinks its now only when braking from say 35-40 mph.
ive had the discs off and cleaned the hubs up with emery paper untill they were spotless.
the discs seam to be running true and fine(not bent)when braking (had it up on axle stands).
anyone any idea's what may be causing it? im starting to run out of patients with it now
thanks guys
I NEVER BROKE IT IT WAS MENT TO BE LIKE THAT!?
i went to college for 8 years to be too qualified huh?
Y.O.L.O. piss everyone off as much as possible ?
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
24-01-2016, 08:23 PM
(This post was last modified: 24-01-2016, 08:24 PM by brodfather11.)
I had a transit once that had those shakes when braking , it was the front discs opening out at the joint between the disc halves. Rust would get in and expanded it more and it got steadily worse. Manufacturing fault.
If the front brakes are OK ,what about the rear drums. If they are oval or cracked you'll get the shakes.
Threads: 4
Thanks Given: 2
(24-01-2016, 08:23 PM)brodfather11 Wrote: I had a transit once that had those shakes when braking , it was the front discs opening out at the joint between the disc halves. Rust would get in and expanded it more and it got steadily worse. Manufacturing fault.
thanks for the quick reply
ill check the rear brakes out tomorrow.
but id say its defo coming from the front as its shaking up through the steering wheel too
it could be an fault with the discs as they were from euro's and it wouldnt be the first time ive had faulted parts from there,even know on inspection they looked fine.
thanks again.....
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
24-01-2016, 09:39 PM
(This post was last modified: 24-01-2016, 09:40 PM by Col.)
Nearly always warped discs, however a mishaped or bulged tyre will do the same. With the wheels off the ground, rotate tyres looking for any bulges particularly in the tread area
Threads: 67
Thanks Given: 238
50
Swap tyres front to rear, easy diagnosis / elimination.
Serieal Berlingo owner
Threads: 23
Thanks Given: 50
29
24-01-2016, 10:46 PM
(This post was last modified: 24-01-2016, 10:49 PM by Jed Clampit.)
Make sure the disc pad's are not loose one of them may be moving about under braking .
Also check the top mount's on the strut's .
Threads: 4
Thanks Given: 2
Thanks for the reply's guys ive re changed the discs and pads with new ones and also swapped tyres from front to rear still got the wobble ?? so will now check strut top mounts.
Thanks again
Threads: 23
Thanks Given: 50
29
One other thing to check well two engine mounting and gear box mount make sure there not loose or gone soft .
Threads: 4
Thanks Received: 4 in 3 posts
Thanks Given: 4
Hi
The best thing to do is take your car to your local mot station and ask to have your car put on the brake roller, they will let you see the fluctuation or run out on the display. You will see each brake individually this is the quickest method. I do this in my own garage for myself and customers.
