Threads: 3
New to the forum but a proud berlingo owner. This alarm came up a few months ago and over the last few weeks the cat has randomly started cutting out. Sometimes does it 2 or 3 tinea a day. Then is fine for a few days then does it again etc. It is a 2010 model 80000 miles. Just wondering if the alarm has anything to do with cutting out etc
Threads: 12
Thanks Given: 16
37
The 2010 model will not have ad blue, you particulate filter additive (Elloys ) fluid will have run out.
This fluid level often coincides with the filter being blocked.
Now it is far from 100% that the blocked DPF is causing the car to cut out.
You had better hope it isn't because of this , because if the DPF filter is this blocked, then you are well on the way to destroying the turbo and the engine.
It is simply madness to ignore warning lights on any modern vehicle, especially a diesel.
My advice to you is DO NOT DRIVE THE CAR AT ALL.
Get it to a garage straight away, that understands these cars, and prepare to part with a fair bit of money, or get someone to remove the DPF completely.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• ron
Thanks Given: 188
23
Why would you ignore an alarm for 2/3 months?????
Are we there yet?????
Threads: 3
Thanks very much for your comments will book it in tomorrow
Threads: 20
Thanks Given: 7
15
When you weigh it up adblue isn't that cheap. The eloys bag is filled every 80,000 miles or so and adblue every 12,500 miles. Over time there isn't a lot of difference in the cost.
