  • 9 Vote(s) - 3.22 Average
Just Self Serviced the van
As per title, just self serviced the van, oil change, belt change, filter change and so on....
Any idea how i make the service indicator go out? Its the little spanner shaped thing.
Thanks in advanced.
I'm about to do this on Saturday
I have this from the Haynes Manuel...
1. On completion of the service, reset the service interval indicator as follows.
2. With the ignition switched off, press and hold the trip meter button.
3. Turn on the ignition switch, and the display begins a countdown .
When the countdown reaches 0, release the trip meter button, and the spanner service symbol in the display will disappear.
4. Turn off the ignition switch.
5. Turn on the ignition switch and check the correct mileage to the next service interval is displayed on the indicator.
Note: If you need to disconnect the battery after carrying out this procedure, lock the vehicle and wait at least 5 minutes. Otherwise the display reset may not register.
Lliam
Hey Lliam, i appreciate that greatly, thanks very much indeed.
Not a problem, It's nice to be able to help
Lliam
Anyone know if there's a different method for the earlier models? - this doesn't work for my 2000 x-reg.
cheers,
Jim
Mk1 and mk2 can be found here
http://www.berlingoforum.co.uk/showthread.php?tid=268
Lliam
Lliam
70 plate Berlingo
Thanks, Did mine today, now 12,500 until next service. (strange the spanner symbol should be on!, it was only serviced by an independent 5K mls ago!)
I had Oil, air, fuel filters all changed with a self service last week.
MPV (My own Personal Vehicle)....2.0 HDi Multispace MPV Mk2 .
I Like Cars,Women,Drink & Motorbikes but not necessarily in that order!
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
