Losing power /juddering
Hello, I have a 05 1.9 diesel berlingo. Problems started about 6 weeks ago. losing power
juddering, white smoke out of exhaust, rattling noise..
Checked computer no faults. Blanker egr valve and this cured rattling noise, white smoke
and most of the power loss / juddering. 90% cured.
but sometimes still getting power loss / juddering around 2000 revs.
no faults on computer, have put injector cleaner in tank.
Starts fine.
Any suggestions would be great
Have you changed the fuel filter recently? Air in fuel?
(27-01-2016, 05:19 PM)ron Wrote:  Have you changed the fuel filter recently? Air in fuel?
Thanks for reply,, New fuel filter,, dose not seem to be any air in fuel
Does it start easily when cold? After about 100,000m the valves tend to tighten up & bad cold starting is 1 symptom.
(28-01-2016, 11:22 PM)ron Wrote:  Does it start easily when cold? After about 100,000m the valves tend to tighten up & bad cold starting is 1 symptom.
Thanks for reply Ron
No van starts fine, even in cold
That's what happened to our 2.0hdi and it was the maf sensor, the car would not rev over 2,500. Try disconnecting it and see if it runs better. It's the connector on the pipe after the air filter. It didn't throw any faults up when it was not working or when it was disconnected. A new one cost me about £45.
(29-01-2016, 10:09 AM)ffrenchie Wrote:  That's what happened to our 2.0hdi and it was the maf sensor, the car would not rev over 2,500. Try disconnecting it and see if it runs better. It's the connector on the pipe after the air filter. It didn't throw any faults up when it was not working or when it was disconnected. A new one cost me about £45.
Thanks for reply
I will try this, But my engine revs up to max fine, its just around 2000 revs it some times loses power /judders briefly
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
