B9 battery charging in situ.
Threads: 20
Thanks Given: 2,126
18
27-01-2016, 05:42 PM
(This post was last modified: 27-01-2016, 05:43 PM by ron.)
I have looked for a thread on this as I thought it was mentioned.Am I right in believing that later cars cannot have their battery charged without disconnecting?I have one of the chargers that are supposed to prevent sulphation etc.If they can't be charged connected,does anyone know why?Thanks fellow members.  PS,it's a 65 plate & I usually charge my battery monthly.
Strawberry flavoured windows
Threads: 9
Thanks Given: 316
15
No Ron you can charge any vehicle with the battery in situ
Threads: 12
Thanks Received: 18 in 16 posts
Thanks Given: 14
6
the battery is being charged by the alternator when the car is running, so no different to using a charger.
so as polar says.
The following 1 user says Thank You to dieselj for this post:1 user says Thank You to dieselj for this post
• ron
Threads: 20
Thanks Given: 2,126
18
Thanks for your replies gents.I read somewhere about the disconnection but could see no reason for it.I've always charged my batteries connected,once a month.Thanks again.
Threads: 6
Thanks Received: 16 in 13 posts
Thanks Given: 11
28-01-2016, 02:38 PM
(This post was last modified: 28-01-2016, 02:38 PM by jamesg.)
(27-01-2016, 10:57 PM)ron Wrote: Thanks for your replies gents.I read somewhere about the disconnection but could see no reason for it.I've always charged my batteries connected,once a month.Thanks again.
I charge my 2011 without disconnecting using the stud on the inner wing. This is with a ctek smart charger.
All my handbooks say to disconnect, but all my chargers say don't bother. I'm guessing it's the manufacturer covering themselves. They don't know what you might connect. I presume it's too high a charge voltage that would do damage?
Threads: 23
Thanks Given: 50
29
I also charge my B 9 with out removing the battery i put it on trickle charge why they say disconnect i don't know just covering their butt's.
Threads: 27
Thanks Received: 29 in 19 posts
Thanks Given: 4
28-01-2016, 05:46 PM
(This post was last modified: 28-01-2016, 05:53 PM by RocketVANman.)
I to use a CTEK charger. I used to go through the process of disconecting charging reconecting etc. Pain in the butt.
Now, after checking with CTEK, they GUARANTEE it will not damage any vehicles whislt charging.
Like jamesg I also charge it using the Battery Pos and Charging stud on the inner wing. I think thisstud is meant for jump starting so it's ideal for trickle/smart charger. The only thing I do is make sure the van is locked and shut down fully before I charge it. I try not to open the doors etc whilst charging but I doubt it makes any difference.
I've been using now for over 2 years and charge my Bingo van, a Pug 307, A modern Nissan and my modern motorbike. Non of them have had any problems at all.
CTEK are a bit pricey but I've read good reveiws on Noco Genius Smart chargers which a more realistically priced.
Just do it and you'll never go back :-)
(28-01-2016, 02:38 PM)jamesg Wrote: (27-01-2016, 10:57 PM)ron Wrote: Thanks for your replies gents.I read somewhere about the disconnection but could see no reason for it.I've always charged my batteries connected,once a month.Thanks again.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Curious as to why you charge it. Do you not use the car much?
Threads: 20
Thanks Given: 2,126
18
28-01-2016, 08:42 PM
(This post was last modified: 28-01-2016, 08:43 PM by ron.)
(28-01-2016, 06:16 PM)`Col Wrote: Curious as to why you charge it. Do you not use the car much?
Hi Col. It's a habit from when I had my workshop 4 miles from home,so I charged it monthly.
My present use,now retired,is some shortish trips & the odd 100+m trip.It can stand for 2 weeks sometimes so I reckon charging it is a preventative measure.Call me overcautious but I've never replaced a battery. Ps.I use a smart charger.
Today 04:31 PM
Today 11:13 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
