Insulating/Carpeting my van #3
The next part was the carpeting. I bought 5m of acoustic carpet that was 1.35m wide and used high temp adhesive. The carpet was wide enough to go across the roof in one nerve-wracking piece. I tucked it under the existing cab lining and worked backwards, the glue remains tacky for a while and the carpet is super stretchy so you can make adjustments. I marked where the rear interior light was (in hindsight this would have been the time to put more lights in etc but I needed to get it sorted for a job at the time) and cut the carpet once the glue had dried. The van came with two MDF boards that I used (assuming they'd be the right size - it turned out they weren't exact hence the gaps in the next post) for the larger panels. For the smaller panels I used some 3mm/5mm ply. I covered them all in the carpet and used some more insulation on the backs of each panel. I was doing this on a budget so wanted to use as little carpet as possible - once I'd got the panels covered I covered the parts that wouldn't be covered by the panels. I used stainless steel self tapping screws to attach the panels. I figured the advantage of using the thicker MDF side panels meant that I could attach storage nets/hooks/webbing etc at a later date.
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
