28-01-2016, 05:14 PM
Washer was not working very well, dribbles out on the jets, so decided to investigate.
I could hear the pump working and there was plenty water in the bottle so suspected blockage. Removed the pump and cleaned. Reassembled but now the pump does not work.
Tested the pump on the bench and all is fine so its not the pump. Checked the supply to the wires going to the pump and no feed. Had a read and someone suggested it may be the fuse in the fuse box next to the battery, no F14 10a, but that's fine.
So scratching head and before I start dismantling steering column to check feed at the switch I thought I would ask here in case someone has any ideas.
Is there a relay for the pump and if so where is it?
Is it fuse f14 or another one.
My car is a 2.0HDi 2005
