Loss of power
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Engine loosing power and a vibration Berlingo going into dealer tomorrow, maybe an injector?!
Car has done 17k.
I DO MISS MY BERLINGO
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
Did you see any fuel leakages under bonnet?
Threads: 63
Thanks Given: 552
Hi PK, no havnt seen any.
Threads: 63
Thanks Given: 552
Ok got car back from dealer and they could not find a problem with a road test or on the machine, they did say maybe it has to develop into a bigger problem or until a warning light comes on.
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
(16-09-2011, 09:03 AM)philip Wrote: Ok got car back from dealer and they could not find a problem with a road test or on the machine, they did say maybe it has to develop into a bigger problem or until a warning light comes on. How's the car now ?- I hope the blingo's loss of power problems disappeared
Former 2011 Mk3 XTR owner  alut:
Threads: 63
Thanks Given: 552
Nope still loosing power from time to time.
Threads: 25
Thanks Given: 44
12
Hi Philip.
Try to change petrol station.
Threads: 2
Thanks Received: 7 in 6 posts
DAft reply, TBH but when you are moving, and its safe to try this, press the footbrake slightly together with the Accel pedal, and see if you loose power, I believe that when you press the foot brake it slightly kills power to the engine, had this problem on an 53 plate Xara Pic exclusive (cruise control fitted) there was 2x micro switches on the pedal on that model., just for your info as that was my problem a few years back..
Threads: 63
Thanks Given: 552
19-11-2011, 07:20 AM
(This post was last modified: 19-11-2011, 07:26 AM by philip.)
(18-11-2011, 09:06 PM)pk7478 Wrote: Hi Philip.
Try to change petrol station. Hmmm never thought of that one, i do normally use either Esso or Morrisons.
(18-11-2011, 10:27 PM)digger Wrote: DAft reply, TBH but when you are moving, and its safe to try this, press the footbrake slightly together with the Accel pedal, and see if you loose power, I believe that when you press the foot brake it slightly kills power to the engine, had this problem on an 53 plate Xara Pic exclusive (cruise control fitted) there was 2x micro switches on the pedal on that model., just for your info as that was my problem a few years back.. Im not going to know if it looses power because of the micro switches or because i have braked  cratch:
Threads: 25
Thanks Given: 44
12
(19-11-2011, 07:20 AM)philip Wrote: (18-11-2011, 09:06 PM)pk7478 Wrote: Hi Philip.
In fact it's a good idea. Several years ago when I used a petrol from BP, i was tire to replace spark plugs every 3000-4000 km. After changing a petrol station everything become ok.
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
