Threads: 9
Thanks Given: 316
15
Hi Rocket, its common mate - i suggest you book it in when you can to have the other side done because if one spring is fatigued then so will the other one.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Just be grateful you don't have a Ford?
Threads: 29
Thanks Given: 67
20
(02-02-2016, 09:48 PM)Col Wrote: Just be grateful you don't have a Ford?
It's exactly the same as a ford if it's a front spring and if it's a rear Ford are easier
I did a front spring on ours a couple of years ago, the other one is still alright and it will get done when it breaks.
Threads: 5
Thanks Given: 3
19
04-02-2016, 02:27 AM
(This post was last modified: 04-02-2016, 02:36 AM by Col.)
I change more Ford springs than any other. Focus, Fiesta & Mondeos have a nasty habit of the broken Spring dropping over the spring cup and the sharp bit of the broken spring can damage the tyre or CV joint boot
The following 1 user says Thank You to Col for this post:1 user says Thank You to Col for this post
• ron
Threads: 27
Thanks Received: 29 in 19 posts
Thanks Given: 4
Had that on wife's Pug a few year back. Broke on a brand new tyre with a few hundred miles on the clock..not cheap tyres either. Even more unhappy as the recovery company had to use wheel dollies to remove the car from the car park. (height restriction) Because it wasn't covered in the policy, £75 charge to use 2 dollies for 5 minutes. Robbing bar stewards
Threads: 5
Thanks Given: 3
19
That will teach me!!! Just had to change a front spring on my Vito today!
Threads: 12
Thanks Given: 16
37
We probably replace 3 or 4 a week, especially with the cold weather, which seems to cause more breakages than ever.
Threads: 29
Thanks Given: 67
20
Citroen recalled the original Berlingo and fitted a cup to the strut to stop the spring from slashing the tyre after a bad accident in France. Mine still has them fitted but a lot I looked at didn't. I have seen the tyre slashed completely in two round the sidewall on a Mondeo with a broken spring. I think you see a lot of broken Ford springs because there are a lot of Ford cars on the road. My daughter had a Corsa and that broke front and rear springs.
