Power steering pump ?
Threads: 21
Thanks Received: 24 in 21 posts
Thanks Given: 133
Hi again
176k now on my little Blingo and the steering feels a tad stiff/weird when its first started up for a few miles then it's much better,had it to my mechanic and he shoved it on the MOT ramp,shook it to bits,spun this,turned that,nothing suspension related at all,no rack leaks but he did reckon the steering fluid ponged burnt ?? I'm away for a break friday so will be leaving it in his hands to do as seen fit (within reason obviously)
He suggested changing the oil ?? no history of it been changed up to me getting her at 38k and I've not done it,I was thinking the pump ? and if it's a pump consensus is there anything else to change while he's in there,auxiliary pulley's etc,the vans got a living to earn and I'd rather get the lot changed while I'm off the road than have some of the work to pay for a few miles down the line.
thanks for your time. Ian.
Thanks Given: 188
23
Good idea to change the fluid also check the universal joint on the bottom of the steering column as the tend to dry out from engine heat and seize up. get some lube onto it and turn steering lock to lock.
Are we there yet?????
Threads: 21
Thanks Given: 133
Threads: 67
Thanks Given: 238
50
Yes WD evaporates quickly and the effect is temporary.
These days I'm getting fond of aerosol grease ( often silicone ) containing PTFE, cheap and blooming effective.
I get mine in the motor factors.
Serieal Berlingo owner
The following 2 users say Thank You to geoff for this post:2 users say Thank You to geoff for this post
• ians_lingo, ron
Threads: 20
Thanks Given: 2,126
18
(17-03-2016, 05:44 PM)geoff Wrote: Yes WD evaporates quickly and the effect is temporary.
Well said Geoff.I use M/cycle chain lube aerosol.It flows into the bearings & then sets.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• ians_lingo
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
(03-02-2016, 08:52 PM)Tomcat3 Wrote: Good idea to change the fluid also check the universal joint on the bottom of the steering column as the tend to dry out from engine heat and seize up. get some lube onto it and turn steering lock to lock.
Were is the bottom of steering column,looked all over engine bay can't see it..? Mine a bit stiff to.is it inside the car??
Thanks Given: 188
23
18-03-2016, 02:40 PM
(This post was last modified: 18-03-2016, 02:40 PM by Tomcat3.)
If you look down behind the engine block where the column comes out you will see the u/j knuckle, on the petrol engines there is a bit of room but the diesels especially the hdi`s its a bit crowded but you can get your hand down there with a can of lube or if you got ramps its easy as long as the undertray is removed.
Thanks Given: 8
5
Its well hidden then I've looked and looked? Can't see nothing coming out of the bulk head,only pipes,will have another look..cheers..
Threads: 21
Thanks Given: 133
(18-03-2016, 03:22 PM)Johny555 Wrote: Its well hidden then I've looked and looked? Can't see nothing coming out of the bulk head,only pipes,will have another look..cheers..
lean in from drivers side,your arm and an oil can (thats what i used) easily reach down to it,the knuckle is only just through the bulkhead,the difference in mine is amazing,too many motorway miles(185000) with hardly any lock to lock stuff,it just started last month and steadily got worse,difficult to diagnose in winter as when it's wet with the spray it worked fine,not rained for last 7 days so it was bad enough to make me have a gander,,
Thanks Given: 8
5
Can u get from underneath? Just can't see anything from the top,? Its 2lt hdi 06 plate.and can see brake servo,pipes,but can't even see steering column coming out of the bulk head..just no room at the back of the engine,?.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
