  • 22 Vote(s) - 3.14 Average
instrument cluster problem
i have a 2004 berlingo 1.9d lx my problem is that the temp gauge and rev counter have stopped working, speedo and fuel gauge still work, any ideas what i need to do to remedy this please Smile
Sounds like you instrument panel is faulty, the only cure that I know of is to replace the whole thing. Get down to your local breakers yard, make sure the instrument panel has the same make as your orignal ones and that the rev counter is the same with the rev max limit and red line limit matching as well, you should be able to get a second hand sent of clocks for around £50, the only problem is that the mileage will most likely be different to the clocks you are taking out.
Roly
2004 Berlingo 600 Enterprise
Confusedafesex: If in doubt flat out!!Confusedafesex:
I thought that instrument panels had to be coded to the BSI
(15-09-2011, 07:29 AM)Romahomepete Wrote:  I thought that instrument panels had to be coded to the BSI
Not that I know of. I have a 04 Berlingo Van with a fuel gauge fault and was told that the gauge in the instrument panel was faulty, I managed to get a breakers yard that let me try two sets of instrument panels, everything worked as it should apart from the fuel gauge on both clocks but the mileage did read different. When I checked with a Citroen dealer they told that the instrument panel was not faulty in my van and that normally you will have a double failure like fuel gauge and rev counter, etc etc.
Roly
(14-09-2011, 10:52 AM)zed35467 Wrote:  i have a 2004 berlingo 1.9d lx my problem is that the temp gauge and rev counter have stopped working, speedo and fuel gauge still work, any ideas what i need to do to remedy this please Smile
Sounds like the instrument cluster is US but best option is to test gauges with Lexia if you are near Doncaster you are welcome to call & I can test it for you .
If you live too far away follow this link :
http://www.frenchcarforum.co.uk/forum/vi...ight=lexia
If you register on this site you can contact members whom have Lexia near you.
2003 Citroën Berlingo 2.0HDi Multispace Desire
[-] The following 1 user says Thank You to BlueBlingo for this post:
  • zed35467
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
