1.9d not starting
Hi all, new to the forums so thanks in advance.
I have an '02 1.9d multispace. Its has stopped starting. It turns over nicely but no combustion. The glow plug light doesnt light up when the key is turned anymore so this has made me think of glow plug problem. I have replaced the relay but this hasnt changed anything. THe relay is getting 12V supply(larger terminal to the rear.
I have a lexia code reader and have had it up and running. Long list of fault codes, first time using a code reader so im struggling to interpret the results.
The faults i get are:
*Permanent fault
evaporator sensor
permanent fault
engine ECU reception
intermittent fault
+ accessory open circuit
*Intermittent fault
 EOBD or engine ECU
intermittent fault
analogue module connection
intermittent fault
no communications from the BSI on the VAN
intermittent fault
Low fuel information short circuit to +
intermittent fault
communication with the instrument panel absent
intermittent fault
communications on the data wire of the comfort network
intermittent fault
communications on the dataB wire of the comfort network
intermittent fault
*alternator
intermittent fault
*engine speed
remote fault
permanent fault
water temperature
Not sure what to make of these codes.
ANyone have any ideas of what to try next?
Thanks again
Hi Sambo,
First thing is to clear all the faults , go for a run, then read them again. The reason is that you don't know the "history" of the faults and many may no longer relevant. You will then be looking at all the "current" fault codes.
HTH,
Griff
Landmark
Ex 1.4 Berlingo Multispace
[-] The following 1 user says Thank You to Landmark for this post:
  • whitebus
Cool, ill clear them all, and see what it comes up with, Cant go for a run though, i take it it will still bring up the errors
Have you taken the glow plugs out and tested them individually?
Looking at this forum:
http://www.bba-reman.com/forums/PrintTopic61696.aspx
Try "inertia switch trigger"
Best regards,
brajomobil
[-] The following 1 user says Thank You to brajomobil for this post:
  • whitebus
So ive cleared the fault codes and now getting the following codes for the BSI:
*PERMANENT FAULT
EVAPORATOR SENSOR
PERMANENT FAULT
ENGINE ECU RECEPTION
REMOTE FAULT
PERMANENT FAULT
WATER TEMPERATURE
polar- got to grab me tools from work so will be testing them later on today.
brajomobile- no hazards flashing but worth a try, what is the procedure for BSI reset without central locking electric windows etc.
thanks
If you don't have remote locking or electric windows just disregard that bit and move on, don't forget to have the window open though. Try this http://www.petercoopercarrepairs.co.uk/p...cedure.htm
Hi, so I've taken the glow plugs out. Tested em and they all are OK.
Done the BSI reset. Still no different. No glow plug light coming up on dash.
Anyone have any ideas of what to try next?
Sent from my Wileyfox Swift using Tapatalk
if you are not getting 12 volts at the glowplugs there is a relay that supplies it . On mine its mounted in front of the engine fuse box, nearside inner wing. Check for a good earth there.
Ok so you have supply voltage at the relay and you have functioning ( tested ) glow plugs, all good so far.
So now you need to see if you have the signal voltage to operate the relay and allow the supply voltage to pass through the relay and get to the plugs.
As far as I know ( I'm no expert ) the relay will require signals from the water temperature sensor and injection pump switch to allow it to operate.
Use a meter to test functionality of the pump switch.
Coolant sensor, perhaps you could try shorting out the terminal / terminals on the connector to test it.
Permanent Fault on evaporator sensor - you have air conditioning ? This may be a red herring.
Permanent Fault on water temperature - this could be your problem ( ecu reception fault could be piggy backed on this and maybe another red herring ).
As said earlier I'm no expert but this would be my path for diagnosis in the light of no other information.
Whether the engine would start with the glow plugs wired direct ( temporarily !! ) I couldn't say - you would need a wiring diagram to determine if the fuel shut off / stop relay is in or out of circuit.
Anyway I hope my ramblings will be of some use to you.
Today 01:01 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
