Threads: 21
Thanks Received: 19 in 17 posts
Thanks Given: 6
Hi Guys, I've got an X reg 1.9 D multispace with 67,000 on the clock, it's a great car but it's developed a very annoying fault. When driving along the hand brake light comes on and the warning beeps, it doesn't do it all the time just now and again and it goes out on it's own. Has anybody got any idea what could be causing it.
Cheers
Doc..
Threads: 32
Thanks Given: 18
handbrake switch faulty?
Threads: 21
Thanks Given: 6
Cheers Steve, I had got it into my mind that it would be a lot more complicated than that, I suppose thats what you get for driving a Mercedes for the last 6 years, everything on Mercs is so complicated.
Doc..
Threads: 5
Thanks Received: 76 in 45 posts
Thanks Given: 19
Could be low brake fluid level.
2003 Citroën Berlingo 2.0HDi Multispace Desire
Threads: 21
Thanks Given: 6
Thanks BlueBlingo, I've just found out from the owners manual that the handbrake warning light doubles as a brake fluid level warning light, I'll check the level when it's light tomorrow.
Doc.
Threads: 5
Thanks Given: 19
Low brake fluid could either be a leak, worn discs and or pads or rear shoes / drums worn
Follow this link which is in the how to section
http://www.berlingoforum.co.uk/showthread.php?tid=1262
Within it You will find loads of info for checking brake components for wear.
Threads: 21
Thanks Given: 6
Panic over, the fluid level was a bit low. I checked the brakes over and all seem quite new and can't find any leaks, topped up the fluid and all is fine.
Doc..
Threads: 2
Thanks Received: 7 in 6 posts
Thanks Given: 6
19-09-2011, 05:51 PM
(This post was last modified: 19-09-2011, 05:52 PM by Phil_G.)
Keep a close eye on it. With yours being a diesel, it is possible that it could be leaking into the servo via the master cylinder seal very slightly, if all else is, as you say, ok.
