09-02-2016, 11:27 PM
Hiya All... Just a few questions..
I am going to check the valve gaps and want to be prepared..
I recon the gaps will be well out as I have had the van 65k miles and never checked them..
I have Googled ( as all good men do ) and seen a method using a sheet of glass and fine wet and dry to thin the shim down. Anyone tried this ?
Another method is to use a wet stone. Anyone tried this ?
There was also a method using a but and bolt and a bench grinder.... this method just made me giggle...
Where did you get your shims from ? Are they all 13mm in DW8 and TUV ?
Thanks in Advance..
Thanks in Advance..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
