Threads: 41
Thanks Received: 31 in 28 posts
Thanks Given: 16
I´m in need of some new tyres which according to the manaul for my 2.0L HDi are 185/65/15 88H.
Do I really need "H" rated tyres, which are for speeds up to 130mph?
I ask as there is a big price difference between "H" rated and "T" rated - the "T" rated ones are good for up to 118mph which is much faster than my Berlingo ( or I ) would ever go.
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
I normaly find V and H rated tyres are cheaper than T rated simply because there are a lot more of these tyres sold than T or even S rated.
I DO MISS MY BERLINGO
Threads: 32
Thanks Given: 18
Michelin energy tyres T rated are a tenner cheaper than H rated.
I use T rated, after all, I don't go over 70.
Threads: 41
Thanks Given: 16
Thanks guys,
I´ve gone for the "T" rated Conti EcoContacts - around £20 each cheaper than the "H" rated.
Threads: 32
Thanks Given: 24
Those are what I run on mine - well within limits and good tyres too
Threads: 51
Thanks Received: 35 in 32 posts
Thanks Given: 3
Sur my 1.6 hdi will only do 92 anyway ffs
Thanks Received: 43 in 34 posts
Thanks Given: 11
I had the same thoughts when I had an XJ6. The tyres needed were Z-rated, but tall, 15" and wide. I looked at lower speed ratings as they were so much cheaper. The advice I got, and not just from tyre dealers, was that the speed rating actually covers much more than just the speed. It part its also a measure of the load (not just the weight, which does have a rating figure, the 88 in yours I think).
The Bus II: 2019 XL Flair 1.2
Threads: 50
Thanks Given: 743
17-09-2011, 12:26 PM
(This post was last modified: 17-09-2011, 12:27 PM by Ol'Jeffers.)
I think i'm correct in saying that, in the UK, a vehicle that has tyres of a lower speed rating than that recommended by the manufacturer will result in an MoT test failure......it certainly does on motorcycles!
