Threads: 65
Thanks Received: 715 in 612 posts
Thanks Given: 225
50
The thing to remember is that folks say to change this and change that but they are not the ones paying !
What people should remember is that ( self ) diagnostics is much cheaper than buying new parts in the hope that it will cure some ill. A few quick test with a multimeter is often all it takes.
I see countless people on the Land Rover Forum I visit ( early vehicles ) repeatedly splashing out on a new battery and then a new / recon starter motor due to a starting issue ( and even then failing to sort it out ! ) without even picking up a meter and spending a max of 10 minutes doing a voltage drop test. This is after offering advice based on experience, nowadays I let them just carry on spending.
Glad you got a result but just wanted to emphasise the benefit of checking before buying.
Serieal Berlingo owner
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Yeah I did and a lot of reading and most of it pointed to a bad starter motor..a common thing on these hdi engines.apparently. he just thought diesel bad cold starting must be glow plugs.any way I told him forget it and went my merry way...I thought £60 for a new starter its worth a try.I didn't want him cutting into wires and putting switches on the dash.and at the end of the day have the same problem...
