  • 17 Vote(s) - 3.18 Average
Berlingo breaker?
Hi
wow, a forum just for Berlingo owners? FAB!!
We have a mk1 'lingo - 1.4 multispace which we need to keep on the road and which needs a bit of TLC
Anyone know who breaks Berlingos?
We need -
seat foam - I can feel current one breaking up underneath me
wipers - bit erratic, common problem?
the full-length sunroof has failed, needs replacing. Citroen want c.£1700 to do so Sad so could do with a secondhand one
front seat belt has a bit of a nick taken out of it - no idea how / when but it'll fail the mot when that comes around (and is a bit dangerous in the meantime!)
Anyway, any ideas on how to maintain our lovely Singapoean import gratefully received!
James
Hi James and welcome
Where are you based?
I'll have a word with the wife....
She is quite adept at breaking things mechanical ExclamationExclamationExclamationSmileSmileSmile
Maybe a thread with a detailed list and contact details would be of use. I.e...
North West
ABC Breakers - 019525 2343 424
for example.
Sounds like a great idea! I will have a think for the OP.
(09-12-2010, 10:55 PM)Andre Wrote:  Maybe a thread with a detailed list and contact details would be of use. I.e...
North West
for example.
Sounds like a great idea, would this be national u.k. or an international basis???
jamesf. We need VIN of your Bilingo to tell you numbers of spareparts.
Seat foam it's a standart problem for all old Bilingos, and as i see you have M49.
Wipers - if you have Valeo. Drop them into trash and install Champion or smth. like this
Seat belts - only replacement.
Hi all
Based in the Yorkshire Dales
Seat foam - assumed it was a fairly 'common' part, just need to find somewhere with one in stock!
Wipers - sorry, not explained myself very well, the motor itself seems jiggered not the blades. Unless you meant the motor too in which case I apologise!! I'll have a look and see if I can spot which make of motor it is over the weekend
VIN - same thing, will unearth it over the next couple of days.
mmm, fitting 2nd hand seat belts not usually a good idea, but you never know someone may have a good one (would need to be green to match existing of course!)
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
