Threads: 2
I have a 2011 berlingo 1.6 diesel van, on my way to work this morning it died on me, i left it for 5 mins and it started again but there was a engine fault warning sign flashing on the dash screen, i made it to my job but later on when out in it again it died,started, drove a short distance, died, started and so on till i made it home.any ideas folks
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
16-02-2016, 05:53 PM
(This post was last modified: 16-02-2016, 05:57 PM by malgpz900.
Edit Reason: add link to map
(16-02-2016, 04:21 PM)mikeydanny1 Wrote: I have a 2011 berlingo 1.6 diesel van, on my way to work this morning it died on me, i left it for 5 mins and it started again but there was a engine fault warning sign flashing on the dash screen, i made it to my job but later on when out in it again it died,started, drove a short distance, died, started and so on till i made it home.any ideas folks
You need to get the codes read on Diagbox/Lexia, with live data readings and post the findings on here. There is a map on here
http://www.berlingoforum.co.uk/thread-1601.html
locating users of diagnostic software. If you make your location a bit more specific someone might pick it up in the post.
if there is no-one local on here, I am also on the Peugeot forum - same software. Plenty of users on there with the software who should be able to help you.
Malcolm.
2001 1.9D Multispace.
Threads: 2
Thanks Malcolm , I'm in the north east of Scotland in aberdeen
Threads: 22
Thanks Given: 8
(16-02-2016, 07:19 PM)mikeydanny1 Wrote: Thanks Malcolm , I'm in the north east of Scotland in aberdeen
There are only three on the Peugeot forum covering Scotland. One in Falkirk, Dunfermline and Fife. Do you want to contact them and see if any cover Aberdeen.
Malcolm.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
seems to me like a fuel problem , filter possibly. As said before a code reader should give you a clue.
