  • 1 Vote(s) - 3 Average
Help air intake manifold leaking
Dear fellow members. I have a 2006 1.6hdi van. I have a leak from the manifold where it sits on top of the engine. I thought it was fuel injectors at first, but apon closer inspection while the engine is Rev to about 3/4 rpm I can see it leaking from the o rings. Problem is I have replaced all the o rings but it is still leaking. Do I need to use any sealant on it . Any help would be appreciated.
Are you sure it's not cracked?
"O" rings don't need sealant unless there is something else wrong
Hi when the engine is running, you can see it coming from o ring. Their is a plastic washer that the o ring sits on that goes on top of engine before o ring but main dealer did not have any part no for them . He wasn't sure what their were for so stuck really what to do
Is this what you are doing ....
[Image: _57_zpsndxvbj6b.jpg]
Unsure about washers but you could use gas ptfe tape wrapped around the rings to help them seal.
Hi that is it. Found out that's it's the plastic end caps that sit on the end of the manifold that you can't get unless you buy a whole new manifold
Last Post: stu76
Today 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
