Threads: 2
Thanks Given: 2
Today in dreadful conditions I had a go at replacing one of my son's tie rods N/S
I couldn't work out how to remove the rubber boot that covers the inner joint.
I tried removing the part it connects too by taking off what I presume is the power steering ram but that didn't help.
Do you just pull it off by hand or does it need getting under with a screwdriver.
I did try with a screwdriver but not knowing how it's fixed I was afraid of damaging it.
Mike
Threads: 67
Thanks Given: 237
50
Hello Mike and please take it the right way but it would seem prudent for you to get yourself a Haynes manual.
Serieal Berlingo owner
Threads: 2
Thanks Given: 2
Well I got the boot off but due to the design they are not re-usable, the boot is glued to a round, serrated washer that once pushed on has to be broken to get off, also the tool I borrowed was unable to undo the round part. I did take a lump hammer and chisel to it but I think you would need an air chisel to get it to move. I have fashioned a boot out of an old inner tube and cable tied it on until the tool and new boot arrive. The boot I made actually works very well!
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 139
33
Its good to see someone using a bit of make do and ingenuity , making something that you need instead of going to a shop and buying it. Your boot may even outlast the new ready made one.
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
Mr MOT tester might not agree Brodfather LOL
Threads: 67
Thanks Given: 237
50
Don't forget to get the tracking done ASAP after completing your work, sucking eggs but you never know.
National Tyres will track for £15 if you print off the online 50% off voucher
