[Brakes] correct parts
Hi Folks,
I am going to replace the brake discs and pads on my 1.4 petrol M59 berlingo.I made an attempt at this a year ago but I abandoned the job because I was sold wrong discs even though I supplied the reg number.I ended up just replacing the pads.
Apparently there are several versions of the discs which could have been fitted!
Is there any way I can buy these parts using the VIN number?Maybe there is another way to ensure  success.
I cant believe I have to dismantle a disc and measure it before I can buy a new one(and then open the packet in the motor factor's shop to check the measurements).
I am not exactly a car guy but I am a hands on technician.
What do you think?
If its a local motor factors you go to , take off an old disc and take it with you if possible .
 If not possible then take one off and measure it. You'll need dia , vented or not , and the height of the disc. ( lay on flat surface and measure how  high.) The OEM make can help  ie Bosch, Lockheed or etc. That is if the brakes have not been changed before.
Sometimes the way you suggest is the only way of getting the right parts , and its not only for Citroen Dodgy
(23-02-2016, 11:28 AM)brodfather11 Wrote:  If its a local motor factors you go to , take off an old disc and take it with you if possible .
+1
  • fernmo
I once thought that clever people in the car industry would use computers to register which parts had been used for each new VIN and then make this information available.Then other clever people would make searchable databases so that it would be easy to find what part was fitted to every vehicle.
Dream on.
Usually a choice of about 3. Could buy all and take back the wrong ones?
  • fernmo
^^^^ That is what my Factors does when the need arises, luckily not too often. This is a common procedure it would seem.
  • fernmo
(23-02-2016, 08:35 PM)Col Wrote:  Usually a choice of about 3. Could buy all and take back the wrong ones?
That is the solution...thanks
B9 Head Unit Upgrade
Last Post: dumdum
Today 01:48 AM
wheels for a 2004
Last Post: Art b
Yesterday 09:54 PM
Poor Brakes - 2006 Partner 1.6HDI Combi
Last Post: GraemeT
Yesterday 05:24 PM
Fault Code P11AB???? No Turbo Assistance
Yesterday 04:59 PM
Hello from Barry
Last Post: JOP3L
Yesterday 04:54 PM
Hello from Helsby
Last Post: cancunia
Yesterday 03:59 PM
Recomend an inverter please
Last Post: lakeside
Yesterday 02:33 PM
Permanent 12v cigarette lighter socket
Yesterday 05:56 AM
Berlingo 2013 double din HELP please
Last Post: Adamg78
Yesterday 05:19 AM
B9 100,000 Service
24-05-2019 11:17 PM
