removal of brake light cluster to change bulb
Hi,
I've just joined as I bought my Multispace XTR 2011 model about 2 months ago. Today a driver behind me in a jam told me my rear brake light isn't working (kind of him tbh as you can't tell when you're driving).
I've had a look at the cluster & the only thing I can see to get it off is there are two screws that look like they would need a small allen key. Is that how you get it off to access the bulbs?
Thanks in advance
Pete
Hi Peter welcome to the forum ive not got a B9 model but I'm sure an owner will be along soon to tell you how to remove the lights. Looking on ebay at the rear lights it looks like you are right and the unit is held on by two bolts http://www.ebay.co.uk/itm/Citroen-Berlin...Swd4tT~eWx
It'll have two screws and will almost certainly also be held on by two pins. You may find it appears tight to come off but that's the way these things are designed.
Current Berlingo: K9 2018 Driver M 100ps in Platinum Grey with Safety Pack
(23-02-2016, 06:11 PM)petergettins Wrote:  Hi,
Thanks in advance
Pete
Pete
the two screws you note are torx head (star head), besides the two screws you need to be aware and gently unclip the retaining clip (see attached photo, have put a square around the clip in question) probably best thing to do is push gently from the outside of the light (push the outside edge inwards)
Also make sure when putting it back to not to pinch the foam as otherwise it will cause water leak in to the back quarter panel and the connector
HTH
Attached Files Thumbnail(s)
[-] The following 2 users say Thank You to manuk for this post:
  • Solent, wake6
There is a tool in with the jack(under the passenger seat) that looks like an allen key but is in fact a torx head 'key' that is there specifically for the purpose of removing the rear light cluster - I only found it when I went to sell my partner and was checking the jack was still there. The tool is there on my new bingo jack too. If I recall is a T40 torx head
Cheers
K
Brilliant everyone, thanks very much. I'll be having a go in the next couple of days. I'll let you know how I get on.
Cheers
Pete
Annoyingly, there is no tool or jack under either the passenger or driver seat. I do have sets of tools and one does have torx head bits, but only goes up to T30, which does feel a bit loose. Looks like I'll have to get a set.
(24-02-2016, 10:59 AM)petergettins Wrote:  Annoyingly, there is no tool or jack under either the passenger or driver seat. I do have sets of tools and one does have torx head bits, but only goes up to T30, which does feel a bit loose. Looks like I'll have to get a set.
Actually I think I was wrong (never happened before Tongue ) - the T40 I used for the roof rails - think it might be a Torx T27 - so you should have one. I'm told you can get a small screwdriver to fit at a push.
See diagram below - item 12 is what is usually tucked in the jack kit.  - you can see it also in photo below - perhaps the jack is within the spare wheel like in the photo
[Image: 00071203.jpg&hash=22b112497e7ca88ce0e36cd3a8d93b33]
[Image: Jack_and_spare_1.jpg]
(23-02-2016, 09:35 PM)manuk Wrote:  Pete
HTH
Thank you so much for this little nugget of knowledge. You have saved me a visit to the garage. I found your post via Google. Thank you!
DAB Signal
Last Post: Brixmis7
Today 11:29 AM
Looking someone with Lexia
Last Post: Tomcat3
Today 10:59 AM
Body Roll
Last Post: Brixmis7
Today 10:16 AM
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Today 08:53 AM
» Replies: 36
Another of lifes great mystery solved.
Last Post: ffrenchie
Today 07:35 AM
Strange T55? Caliper Bolts
Today 07:22 AM
DS3 steering wheel swap
Last Post: Zion
Today 06:36 AM
Coil over clarity for 2015 van
Last Post: Zion
Today 06:03 AM
» Replies: 56
B9 - key fob/ignition/starting problem?
Last Post: Zion
Yesterday 11:22 PM
» Replies: 15
New Firmware update for 2020 Berlingo Van!
Yesterday 08:40 PM
